- Panama City, Fl
- Other
Hey guys,
We have been working on a sound deadening solution for a few months and now have a DIY kit in our web store.
This kit includes a sheet of 1 inch thick sound suppression material which includes two foam layers, one noise reduction layer sandwiched in between and a mylar film layer on the outside plus a psa layer on the back. The sheet size is 54" x 96" so you should be able to get a lot done with this sheet.
The kit also includes a gasket material for your engine hatch (20 feet) and contact cement to secure it in place.
One additional feature that we're going to include is the fire port donut. It is basically a small piece of the noise reduction material that installs inside your fire port to reduce noise that escapes through that opening.
Also the kit includes installation tape and hangers which can be epoxied to the side walls of your engine bay. This will help the material stay put far longer than just using the PSA. Images are below and also available on our site:
https://jetboatpilot.com/index.php?id_product=550&controller=product
Shipping should average around $30 depending on where you live in the US.
I don't have an image of the hangers but I can get one online next week.
Our recommendation is to install on the forward facing portion of your engine hatch and sides of your engine bay. We've found that most of the sound that can be reduced is coming from the engine hatch opening and the noise that escapes around the panels that are screwed down in the engine bay's port and starboard sides.
We don't have data that will show a reduction in noise but I can tell you that when we installed ours the noise in the cockpit was reduced by a noticeable amount. I can't seem to find a noise measuring device that can confirm what I can hear with my ears, and so I can't publish DB reduction numbers.
We hope that you will give us feedback after you've done your own installs and let us know what you feel your results are. This is a product that we've been wanting to do for a long time and people ask us for it all the time so I need you to help us finetune it and tell others about your experience.
Also you will be comforted to know that this material is rated to be used in engine compartments and will not cause a fire hazard on your boat.
As always please call me if you have any questions. Will at 850-960-3236
