Mainah
- Chapin, SC
- Limited S
JL released their “new” M6 series at the Miami boat show last week. Basically a cool cosmetic refresh along with behind the cone rgb translucent rgb lighting. I like the new style and lighting. Theses are replacing the M series and rumor has it the mx series will be getting a refrah before the end of the year as well.
That said when I called Odin at earmarkcaraudio he is clearing out his new in box old stock of the M series to make room for the m6. He offered such a great deal on a m880 tower package that I did not go with the new style m6 series. I asked and he gave me the ok to post about this clearance deal and he said would have a shipment of the new m6 series at his shop very soon.
If you were on the fence about adding matching speakers to your m or mx equipped boat now is the time to do it for a great deal and before they are gone.
Also chatted about rgb noise with Odin. He said that cheap rgb controllers on the same power source (battery bank) as the head unit amd amp are prone to this due to poor components. Isolating the controler or powering the rgbs with just ground and single color with no dimmer will help with this if a problem. He also only uses shielded av or security wire in his rgb installs.
I did not recieve any compensation of any kind for this post. I do have an affinity for great quality (JL is the top of the heap in audio) and great customer service (Odin knows his stuff and takes care of the folks on this forum so we should return the favor).
@Earmark Marine
@Earmark Marine
