The Cobra Jet fins / fangs stay down in the water always and do effect handling going forward. Good luck and enjoy that great boat.
Could just be the wind too. My boat will do that too and the nozzles are adjusted. That’s where @Mainah push button stop and start are handy. Push the button to stop, pull in the fenders, push the button to start and your on your way again without getting dizzy.First thing I'm gonna get is some of the fins (can't remember what they are called) that help the boat steer straight. I let go of the steering wheel this past weekend to grab a beer out of the cooler and the boat started spinning in circles.
Did you drill a new hole for the fang like @ttzz did or move the fin up one hole to get clearance for the lateral thrusters? I’m doing this later today and hoping I can just move the fin up one screw hole not that I want to.Cobra makes a variety of products for our boats. The original AK fins/ fangs , my current and preferred configuration , do not adjust and are always down in the water both forward and reverse.. The mega's may very well be adjustable but I like the original fangs combined with JBP's lateral thrusters. The best of both worlds IMHO.View attachment 82122
You are correct i didn’t catch that.OP has an e series with the built in push buttons so my standard kit will not work for him. However if an eseries owner want single button start and stop that is some that I could do and never thought of till now.
Did you r
I did drill a new hole on each fin just like @ttzz picture. Not really sure that it was necessary and may not have blocked the lateral thruster output on the lowest stock hole ? Was not difficult , just be sure you have a good bit and a steady hand . Measure twice and drill once !! lol
My fangs are in the way a little when straight but as soon as you turn the wheel their out of the way. Im thinking I may try it in the stock position, the only time it might be an issue is straight back with a lot of throttle. Still thinking this over I don’t want to break something.Yeah it’s close on the stock hole, I almost didn’t do it myself but if you really look closely it does obstruct it slight at certain turn angles. However at full over when the thruster is fully engaged it is really close to being out of the way. Like you said though it’s easy to do so why not be sure it’s out of the way at all angles of engagement.
Edit: just a hint for anyone who does this, I found it easy to put the top bolt in the fang then swing the fang down to a point where it clears the LT and mark with a pencil. Then drill the hole and then lay it on top of the other one and use it as a template to mark the other fin and drill that hole - done.
It might just be a little more “power steering affect”.Cool - Let us know how that works out, be a good experiment/information for those doing this setup in the future. Like I said I almost tried it this way before I decided to modify it. Personally I didn't like how close they would be to obstructing the lateral stream at slight turns but in reality it may not make a difference.
Do you think with the fang being more in the water it will put outward stress on the fin? Just a thought that ran through my brain after reading this.Who knows, but actually if I had to guess I'd say the opposite, dropping them down like I did will actually increase their effectiveness in power steering and tracking cause they are below the ride plate and have greater influence in the water passing by. In the original placement they sit higher above the ride plate and less in the water stream (see image comparison below). Its one of the reasons I surmised that they had such a dramatic affect on tracking for me. But its all just kinda guessing - the real test is do you like what the setup does for you, if you do, that's all that really matters anyway.
