treeskier
Jetboaters Commander
- Ocean City, MD
- 275SE
Today was the day I picked up the 2016 242 Limited S from storage that I had purchased from a good friend last March (he has a new 26 footer). Its been a long spring having a new bulkhead, pier and lift installed. Finally, everything is finished enough to get the boat on the lift (the electrician still has a few odds and ends to clean up). I am sure this will be one of many posts asking for assistance on items that are different from my old '02 LS2000 (still need to change the picture in my signature).
So here is the first question. I have a start battery switch, a house battery switch and a third switch that is I guess a back-up for low voltage situations. When the boat is on the lift the plug is in and I was told all 3 battery switches should be in the off position (I guess that's to keep voltage from draining off and killing the batteries). In the event it rains while the boat is on the lift how will the bilge pump run in automatic mode with everything in the off position ? My guess is it won't run so in that case I need to do something differently?
Thanks - Joe
Thanks - Joe
