tlchase99
- LS
I’m thinking about buying the lateral thrusters and thrust vectors for my AR250, but was wondering what your opinion is on them since it looks like you’ve had them for a year now. Thanks.Just installed my new Lateral and Vector Thrusters on my 2018 AR240. Have not had a chance to test it yet. What should I expect?
Looks like I’ll be getting a newer boat soon and may try the Cobra Jet fins instead but they are more $$$.
With the CJS the added benefit beyond the improved low speed handling, is the improved steering at all speeds. They definately are great when pulling tubers and such since they increase steering control substantially.
Do you have lateral thrusters as well or just the CJS?
It sounds like the lateral thruster / CJS combo is pretty effective.
I have both on mine. It should work on yours. I had to drill a new hole to move the small fins up enough to clear the lateral thrusters.Do you have lateral thrusters as well or just the CJS?
The small fins are called mega fang plus and they are made to improve real reverse by concentrating the reverse thrust that exits the bottom of the original nozzle, they also direct that thrust better and provide better stopping power as well as backing power with a power steering effect added also. The lateral thrusters bleed off the existing reverse power and stopping power to provide some side thrust but twin engine boats can duplicate that easily by using the duel throttles and not loose out on the backing and stopping power provided by Yamaha in the original design. the power steering effect is created by the outer fangs going forward of the nozzle pivot point and at speed they help turn the nozzles I see Yamaha used the same principal; on the rudders of the 19 foot boats , look at the front of the rudder forward of the pivot point and you will see a forward leading fang.I have both on mine. It should work on yours. I had to drill a new hole to move the small fins up enough to clear the lateral thrusters.
Looking at my jets on my ‘22 AR250 and from what I’ve read online Yamaha changed the design and added their own version of a lateral thruster I think in ‘19. I’m guessing that’s why I don’t have any complaints on my maneuvering at the dock bc I use my jets opposite of each other to spin my boat around on a dime and can maneuver sideways up to a dock pretty well . My question is, looking at the photos of your CJS there is a plate that mounts on the inside of both jets and appears to block those factory lateral thrusters. I want the boat to track better at high speeds but I don’t want to give up the precision at the dock. Can you elaborate on why it won’t effect these thrusters or supply me a better photo of it not blocking those thrusters when installed? Thanks for your time.The small fins are called mega fang plus and they are made to improve real reverse by concentrating the reverse thrust that exits the bottom of the original nozzle, they also direct that thrust better and provide better stopping power as well as backing power with a power steering effect added also. The lateral thrusters bleed off the existing reverse power and stopping power to provide some side thrust but twin engine boats can duplicate that easily by using the duel throttles and not loose out on the backing and stopping power provided by Yamaha in the original design. the power steering effect is created by the outer fangs going forward of the nozzle pivot point and at speed they help turn the nozzles I see Yamaha used the same principal; on the rudders of the 19 foot boats , look at the front of the rudder forward of the pivot point and you will see a forward leading fang.
Perfect photo, thank you for the explanation.Yamaha has angled thrust on the bottom of the 2019 and newer nozzles on my 2019 and newer systems called AK-19 versions the fins have a cut out in the front and I instruct you to set the outside fins up 1 notch to allow for those thrusters to work very simple remember my fins are carefully positioned in relation to the hull and the rudder, Yamaha did not aim those nozzles horizontally and they did not make them opposing for good reason so my fins allow them clearance easily remember I have been doing this for 22 years It's what I do View attachment 206923
