treeskier
Jetboaters Commander
- Ocean City, MD
- 275SE
This season we upgraded from a 2016 242 Limited S to a lightly used 2019 275SE. There are many things that are system improvements over the older boats. To name a few I love the new clean out plugs and that the bilge pump will run with the batteries off (we are on a lift so our drain plug is always in).\\
When I start up from cold I turn both start and house battery on let the Contex completely load and then turn the key to the on position so I am ready to start then the reverse when back to the lift ...key off wait 30 seconds then kill both batteries at the switches connect the trickle charger to the house battery.
Here's the question if I turn on the house battery only I get a low start battery voltage alert (since the switch is off not surprising)...I would do this if I want to run the audio system while on the lift or floating. Is it an issue to leave the start battery switch on to avoid the alarm? Is there something else I should be doing? On the 2016 we only had the start battery on when we were underway. We'd switch it off while floating using the audio etc.
I haven't had any battery drain issues so far.
