josephjbrown
- Limited S
Hello all,
We recently picked up a 2014 Limited S that the broker knew very little about as it appears after our first few experiences with it and I have some questions. This may not be the right place but I figured it's a good place to start.
1) The boat was advertised as fresh water use but the jet pumps definitely have some barnacle growth on them. I've looked at a few chemicals to strip them off and while they're all old and dried up I'm sure they're robbing some power from the boat in friction. Should I be patient & remove the pumps over the winter (New England has plrnty of down time unfortunately) and have the soda blasted or something like that?
2) There's cobra jet fins and the bottom plates that act as the stop for the fins are loose and seem to rattle a bit. I'm afraid to try to tighten it too much because the pump is aluminum and stripping that bottom steering bolt would be very bad from what I can tell. Does anyone have any input that could be helpful around the cobra jet on this year specifically? the boat still has tons of side slip and over steer but I expected that and with two engines I'm able to overcome that for the most part so I am strongly considering removing the fins completely. Thoughts? Opinions?
3) Tower courtesy lights aren't working which is a minor annoyance but the breaker/fuse seems ok. Thoughts? Opinions?
