New Wear Ring and Impeller Questions
Buckeye Boater
X
Hey guys, I want to replace the wear ring and impeller on my 2015 AR192. I'd like to have the plastic insert wear ring and a stock, but stainless, impeller. Could someone point me to the correct part #'s and where to order from? I've looked around but I haven't seen anything specific to my boat.
Thanks.
Thanks guys. Do you put any kind of sealant around the housing when you put it all back together?
Yes. Remember to seal the pump as well with silicone.
Stupid question, but I am pretty mechanically challenged. What kind of sealant and silicone would you use? I have to replace my impeller as well.
Stupid question, but I am pretty mechanically challenged. What kind of sealant and silicone would you use? I'm have to replace my impeller as well.
I use anti seize on the impeller threads, high temperature thread sealant on all of the bolts and cheap hardware store silicone caulk between the pump housing sections. I have used better products between the housings but doing so makes them difficult to disassemble.
