Devorda
Hello! I just purchased a new 2020 AR240. Previously we owned a 2008 AR230, which we upgraded the stereo. Wanted to reach out to see if any of you have insight on a few questions.
here is the plan currently:
I purchased the fusion wiring harnesses to get the RCA and remote from the back platform head unit. Going to run them to the battery compartment where I will house all 3 amps and subwoofer. Plan to add another house battery to help with the amps, as well as a dual bank charger while I am in there with the tools. I am planning a 10” wetsounds sub and amp, 4- Revo 6 speakers to replace the cabin speakers, and 2 Rev10 tower speakers. I will also be installing the wetsounds 420 equalizer to have adjustability for the sound. I believe I have adequate amps to run all of these (3 amps).
My questions:
1) which tower (front or back post) did most of you run the speaker wires in?
2) do you see any issues with the stereo I have going here?
3) will I have to cut out for the wetsounds revo 6 main cabin speakers- or do they use the same size hole as factory?
4) if having to make the factory speaker holes bigger, any suggestions on what to use? Hopefully it will not be much cutting as it should be somewhat close?
5) where would you run the RCAs to best conceal them going across the boat (engine bay??) ?
6) should I integrate the power cable for the amps into the battery on/off switch for the house batteries, or go direct to the amp from the battery?
7) any other insight or issues I may run into?
thanks
Dan
My questions:
thanks
Dan
