Cruiser13
Hello all. I have a 2013 AR190. I had the no communication error show up on the tach last September and the rpm gauge would bounce all over the place. It didn't seem to affect the boat and I continued using it through October. The no communication error would start when I rev the boat past 4k rpms. Using no wake mode out of the marina and there is no error, but when I opened the throttle it would come on. I reset the tach, cleaned the battery connections, and bought a new battery. The last time I took the boat out in October it started shutting off and throwing alarm code. I took the boat to get weatherized in December and the shop said it needed a new tachometer since it wouldn't show RPM's above 3500 and it would stick. I put in a new tach and took it out today and the no communication error returned. However the boat didn't shut off and throw alarms today. Any suggestions? I don't want to replace the ECU if that doesn't solve the problem. It seems like a connection issue since it starts when the boat gets up in the rpms. I unplugged all the electrical plugs and reinstalled them.
