TN_seamonkey
- Chattanooga, TN
- SX195
Hi all!
So, I just picked up a 2017 SX195 last week and I can't find a single iota of information on the Shoreland'r trailer it came on. I mean, I found the maintenance manual, but not like an owners or instruction manual. The reason I'm looking for info is because this trailer obviously has brakes, but I have no idea how they work. The electrical connector is some oddball 5pin flat connector that, as far as I can tell, has no mate on any standard towing harness wiring. In addition to that, the previous owner broke the pin off of the blue wire so the connector would fit the standard 4pin flat connector. I'm thinking perhaps that blue wire controls the brakes, and therefore I have no brakes on my trailer. I've attached a photo of the busted 5pin connector for your pleasure.
Oh! Also in the photo you'll see that little 'pin' thing he wire tied to the tongue. He said it was something like a brake override?? I googled it and it looks like that piece to disable surge brakes when you're backing up, but this trailer doesn't appear to have surge brakes.
Any ideas? This is apparently the trailer that went out with all of the SX192s in 2017, so there are probably a ton of these out there.
Thanks!
Mike
Thanks!
Mike
