No power to fuel pump
Marvin willis
Morehead city nc
Motor wouldn't start. Replaced plugs. Still no go. Plugs were dry. Tried testing power to the pump and got nothing. Please help. Looking like no boat for vacation again
The fuse should be in the back of the engine bay behind a black cover.
Not the fuse. Can't find the relay but there was some water in the black box
Man, that sucks! Did you confirm bad ecu by swapping engine connections?
I'm not sure where the best place to get one from quickly will be, but others will surely chime in. You may want to post that question in the General Discussion section to get more responses.
Put bad one on good side no go. Switched the other way both motors run
Yamahasportsaza only shows jet skis no boats. But looks like they have one for less than 1000
