jjtherocketman
- Mims FL
- LS
Have looked through threads here seeking a "no spark condition" but haven't found anything that seems to fit yet. I have a 2000 Yamaha LS2000 with twin 135hp motors. Boat has been running great, but last time out, had port engine die on me and had to limp back in. Since that time, I've checked all of the obvious kill switches (lanyard, clean out port switches, ignition switch, and neutral switch). Checked resistance on all and they were all correct per the manual, and then even swapped connections on each. In all cases, starboard engine still fires right up and port turns over, but doesn't appear to pop and start. Appears I have good gas flow, changed fuel filter and that filled right back up. Tried starter fluid (usually need starter fluid to start either engine after they sit for a few days once gas drains back into tank), but that isn't getting any pop out of the port engine either. Plugs look fine. Think I have it narrowed down to the ignition system box on the back bulkhead as a result of all the other checks. Has anyone had any experiences with some component failing in that box? CDI?
Any suggestions would really be appreciated
