Tobes
Jetboaters Commander
- Las Vegas
- AR195
So I have no spark on #1 cylinder. I pulled the injectors and tested everything. Each coil pack works but none work on cylinder #1. Spark plug also works on all except #1. At this point, it has to be an electrical issue somewhere behind the coil.
Before I go ripping the harness apart, any thoughts? The wires do not seem loose at the connector either. 200 hours 2015 AR190 (1.8L NA).
