Mercado
- IA
Hey friends. 2nd season with my 08 AR230 HO freshwater only. Pissers were fine this spring when I de-winterized on the garden hose. First time out this year there was no water coming out either of the pissers at idle or cruising speeds. No overheat alarms yet. Only had a 6" length of zip tie to check if they were plugged. That did not resolve this issue. Next time I get to the boat I will try using weed whacker line (how many feet do I need?), I will check lines to make sure they are not kinked/holes/or air, I don't know how to flush the system yet. I've searched some of the forum threads/videos already. What else should I check/do to diagnose/resolve the issue?
