BBoater
- 252XE
I bought a NOCO 5x2 Charger and was planning to leave it wired up to my batteries. When I tried charging the batteries it tripped the voltage sensing relay. Forgot to consider that. I understand the VSR connects the batteries together when the red light is on.
Is it OK to have the 5x2 connected to each battery. It should be feeding 5 amps in on each battery, safe when they are connected together?. Or should i just use a single charger on the Starter battery and let the VSR flip over to house similar to when the boat is running?
