sbeassie
- Baton Rouge
- 222SD
Finished installing two new amps this past weekend. But I have what is probably ground loop noise. When I connect RCA cables to my new Wet Sounds HTM-8 I get a high-pitched tone noise. Not very loud but very noticeable and annoying. This amp is to drive the 6 OE 6.5" speakers and a new pair of tower speakers. I haven't mounted the tower speakers yet. I also haven't installed the sub yet or connected anything but power and ground to the mono amp. Just trying to drive the OE speakers for now. I have the power and ground for my new amps connected directly to the positive and negative posts of the house battery. The signals are from the factory wiring from the Connext system using harness adapters. There is no noise when I plug my phone directly into the amp using a lightning to RCA adapter. Any suggestions on a possible cause or a solution?
