Noise Reduction on an 2007 Ar230
Jbaref2
What's the best way to get the noise down any tips or best possible products on the market
Not getting responses because this is asked so often and there some great write ups. Check the member tips for sure.
https://jetboaters.net/threads/engine-compartment-insulation.3574/#post-91942
By far the lowest cost & lowest pain option with significant noise reduction performance in our boats is the bulb seal mod, IMHO (my 2008 SX-230 has identical hull & mechanicals with your 2007 AR-230).
See link above. I did it and the improvement was very nice, cost was <$30 and if you can operate scissors and peel & stick, you can DIY this. Additional bonus: zero added weight (well, OK, maybe 10 ounces all-in).
Try searching "bulb seal" or variations thereof. The above link should have the exact McMaster Carr catalog link. If it does not, tap me back and I will dig more.
Worth noting: This mod likely will need some partial re-do every couple seasons, but still is easily the best bang for the buck noise abatement for the '07-'09 230 series boats I've seen, by far.
West Maine sells some killer engine room sound material. It's closed cell / vinyl, open cell, about 1" thick. I put it in my diesel e450 and it made a huge difference.
