I added a gasket around the engine compartment. Much less engine noise. Now I hear most of the noise coming from the ski and fuel compartments. I think it's vibration from the impeller vibrating and making the high pitch noise we hear thru those compartments.
When I first repitched my stock impeller, it was smooth and quiet. Following impellers and pitches have not been as smooth, and noise increased with the vibration.
I think a sound deadning material would help dampen these vibrations.
If vibration/noise is a big problem, you might want to pull your impeller and check it out. Small dings can be filed out easily, or you can send it to Impros or Skat for a repair job. Don't be scared of pulling the pump, it's not hard at all.
@swatski tried different impellers on his 190, maybe he could add input on the impeller vibration/noise connection.
