O2 sensor location
scarabdave
Michigan
Scarab
HO Impulse
I have a 2017 215 with 200s, 73hrs. No previous issues and the other day we were out cruising, shut the engines down and then when I fired them back up got a check engine light and p1130 code on starboard engine. I know it’s an o2 sensor but I’m not sure where it is located. Does anyone have any pictures of where the location the o2 sensor is? Thank you in advance
I don't have a picture but they are easy to find. They are screwed right before (and after) the cat in the exhaust line and connected via a cable. Can't miss them ?
Can I get a new sensor from an auto parts stor or do I need to get it from a dealer?
Part store will work, but they need to be changed to the right connection. Naturally brp is using its own connectors, but it's no biggie.
Awesome thank you! I’m assuming I need either the dealer or a computer to reset the check engine light?
I think you can do it with CanDoo pro, I still haven't connected it to mine to see what I have access to.
