O2 Sensors, 2014 Scarab 195 HOI
ChristopherDHall
Scarab
HO Impulse
Searched and searched and finally found the ones! 13444, Bosch
You’ll get a code on your dash when they do.
PO13F / PO13A
Thanks!
I know it’s an old thread but how did the 13444 O2 sensor work out? When I pulled my O2 sensor or cross referenced to a 18127 but the 13444 looks like a perfect fit.
HI, bumping this thread again as I'm also interested in whether the 13444 sensor worked? I have a fault code for my pre-cat port side sensor but am having real difficulty locating either a Bosch 18127 sensor or the OEM versions to replace it.
I have used other brands and pt no from various companies and as long as the sensing unit and the connector are identical go for it; just make sure the wires are long enough. Worked for me.
out of curiosity, since there are two O2 sensors per motor, are both the same model numbers?
