OEM ballast bag repair
JetDrew1332
212X
Looking for advice on a ballast bag repair. Just purchased a 2014 212X and removed the bags for winterizing and inspection and found a patch on one but doesn't appear to be holding well anymore. Not sure if it's PVC material. Any advice would be greatly appreciated!
You'd be better off replacing it. Wakemakers likely has a replacement or close to a replacement for that. I've not seen patches and things last very long or work very well on ballast bags. Those tend to be temp fixes to get you through a short period of time until a new one can be bought.
OK, thanks for the advice!
I had a mouse eat through my swimdeck ballast bag. I was considering taking it to a tire shop for one of their vulcanized patches. They are just too darn expensive not to try.
I took the advice given by suke and ordered a new OEM ballast bag from Partzilla. Considering how it is tucked away deep under the seat, i didnt want to risk a leak. Although the patch that is currently on there didnt leak when i filled it during this last season. It was only $178 with tax and shipping, which isn't to bad. I am going to keep the old one and try a new patch but keep it as an extra to place either on the deck or in the ski locker for extra weight. Also going to buy a sumo pump (or equivalent) to fill/drain it. I had planned on buying extra ballast bags and a pump for next season anyway. So if it works, great! If not, still worth a try. I found a bunch of pvc patch kits online. Now just gotta decide on one will work the best for this application.
Try these, I have used them on towables that take a beating and have never come off or leaked. Applied them following the directions indicated then clamped over them to dry with the trigger clamps from harbor freight - the ones with the flat rubber orange ends on them. Once dry then added a little extra glue around the edges as a final touch.
I have used those to patch ski tubes on a regular basis. I just felt the swimdeck bag was a much heavier material and had to support much more pressure. It's a small investment to give it a try for sure.
OK, thanks! I was leaning towards pool liner patches or inflatable raft patches. I'll give these a try.
I had a leaking fill fitting (point of maximum stress) on a huge bag (over 1000 pounds) and absolutely smothered it in 3M 5200 (used the entire tube). It actually held for a couple years.
3M makes some good stuff. Thanks for the advice!
