paleus
I just picked up our 2016 AR240.
It's got about 240 hours on it and has been very well taken care of by the previous owner. It came with the wake booster, a ski locker ballast bag, and a transom bag. The stereo has been upgraded with all JL and has a sub next to the driver seat and tower speakers added. The kids are very excited, but maybe not as much as I am.
Now for some questions I'd love some help with:
Are there any things in particular that I need to check on or address?
The boat did pull to starboard a little when I test drove it. It wasn't wind, it did it both directions. The port side nozzle was toed in slightly. I used a 4 ft level and adjusted that nozzle to be parallel with the other nozzle and the rudder. Going to test it today. Any other things to check here?
The owner says they did suck up a rope in the port jet, but that was 4 years ago and haven't had any problems after clearing it. Any potential issues caused by this?
The boat wants to spin to port in neutral, are there any specs for what the gap should be on the reverse gates when in neutral? Or is that something that just has to be played with to balance it out?
I'm thinking I want to remove the graphics and change to something more classic looking or just leave it all white. Am I in for a pain the butt removing the decals on an almost 10 year old boat? Would I be able to buff out the gel coat to remove any ghosting left from them?
Pretty sure the tires are original so I'll be replacing them ASAP. They're also bias ply. Just glad I didn't have any trouble from them on the 3 hour drive home.
Probably going to put a Ridesteady in over the winter.
I thought about adding TVs or Cobra fins, but I want to drive it how it is for a little bit. The lateral thrusters look like they'd help more than anything for docking. I've heard fins can make for a less good surf wake as well.
Definitely going to add some guide poles on the trailer. Maybe steps on the front of the trailer.
What products do you recommend to clean the vinyl? Would simple green be safe to use? I'll put 303 protectant on it after cleaning too.
Overall, the whole family is completely pumped over it. Hope to get quite a few years of great memories with the kids on this boat.
