Jamlewis
- Canyon Lake, TX
- AR195
Its about time to change the oil, and was looking in the user manual at the service intervals and oil capacity ( see attached images). For the Oil Change interval, the language used in the the manual says the initial oil change is at 10 hours, then says "Thereafter every" 50 hours. You could take that as the next oil change is due at 60 hours total instead of at 50 hours. What do you guys think? I am at 49 hours so going to change it soon anyway, just thought the wording was a little ambiguous. Also, on the capacity the manual states "Engine Total Qty" as 5.3 L but the oil qty with filter is 3.7L. How much oil should I expect to get out? I assume 5.3L is the volume of the oil pan, but not how much oil is in it? Thoughts?
