Yogi72
Changing the oil on my ar230. While doing so a portion of a zip tie fell into the oil cooler where you fill the oil. What would you recommend doing?leaving it, have the entire oil cooler removed for the object (it is a small zip tie that was zipped together) I notice there is a screen in the oil cooler to prevent from going into the engine.
