Floydy
- Scarab
- 165 ID
Hello,
Did an oil change this weekend on my 250HO. The oil filter cover bolt was incredibly tight. Took in the order of 70 ft lbs torque to break it free and it didn't help that a previous owner had damaged the E10 Torx head by using a regular socket but it eventually came free. However the cover/bolt assembly was different to the service manual and I'm wondering what is normal? Firstly, I have no spring. The new filter is held in place with the pressure of the cover. The cover bolt has a sleeve around it which is held in place by a flange nut at the bottom. However that assembly is loose and the sleeve moves up and down about 1/8". That flange nut is also very tight but I can't see what actually makes it tight as there is thread evident on the bolt above and below the nut. There is also no small o-ring in that bolt assembly, the only o rings are the two in the cover. Does this sound the same as your bolt assemblies? Do you all have springs under the filter cover? Thanks in advance.
