Oil pressure warning
caborouse07
Key West Fl
I have an 2005 AR230. I had an issue this weekend with battery switch being corroded and had to replace. After completing the change the engines start right back up. However one of the engines had a low oil pressure light come on. I turned it off and waited like 10 min. to restart. I check oil level and it was fine. After that the light never came back on, I used the boat for the rest of the day with no issues. Is this something that is common after disconnecting the battery? Anything to be concerned about?
I wouldn't say it was common but it doesn't surprise me or worry me, you checked the level, it was fine, go have a good time, check the oil at every launch and monitor it further,
sometimes you lights will blink to tell you what engine code is alerting,
I would suggest a YDS to monitor the engines yourself even while your running,
check out the thread in my signature below for common issues with your boat,
Thanks, do you have a recommendation on the YDS diagnostic kit. I see several on ebay?
