- Florida
- Other
- Other
Well you can add a little gear lube to it also but you pump some grease into the syringe and then push it into the fitting opening not a lot though, I never measure it and I seldom bother doing it because as long as the seals are good the grease won't go away and water won't get in. You probable only need to check the condition of the grease once a year, and if it looks ok it probably needs nothing.
