Trevor Shipman
- Charlotte, NC
2xVisually it looks good, but not sure how comfortable it will be for someone sitting there.
Do you like the way the speakers look on the back deck? We desperately wanted sound back there and putting them behind the seats was disappointing. I'm a "it should look factory" type of guy. Curious what you guys think.
I'm the worst about taking photos along the way. Here a couple to give you an idea. Rather than screwing the speaker in, we used a bolt so it would pull into the cushion nicely. You'll see in the 2nd photo where w had the speaker behind the seat, now we have 2 big holes that I'm not too thrilled about. I wouldn't suggest behind the seat application leaves much to be desired. We also made the mistake of buying a Pyle 6x9, they sounded horrible. Threw the right in the trash.Looks great..same concerns about comfort...but if you say you are comfortable...thats all that matters! Got any photos and info on how you modified the cushions?
We only put it on the tweeter, no bass coming out of those.Putting one of those foam baffles around the speaker will absolutely reduce bass response. You're essentially taking a speaker that was designed to acoustic suspension and placing it in a small enclosure.
No... Just the tweeter.Did you put the foam rear cone on the Polk 6x9s too? I did that with mine and ended up taking them off as it seemed like it defeated the bass response.
Never really been a fan of how they looked. Plus the bimini top gets in the way.Why didn't you just opt for tower speakers?
