jebwm
- SR
So the last couple of time that I've taken the boat out, the starboard engine cranks right over, but the port engine takes some fussing with to get it to stay running. Allow me to elaborate a bit...
I can hold the key forever and it will try and crank all day long. Eventually it will start to run but then stall out. After I do this a few times it will run longer and longer each time before it tries to stall out again. Once I get it to a point where it will run for 15-20 seconds, I just gun it and it seemingly clears itself out. Today the RMPS were limited to around 6k for like 5 seconds then shot right up to 10k where it was supposed to be. To make this even more tricky (or perhaps simpler), once I do all of this it is fine for the rest of the day. It's only when I first put the boat in the water that I have this issue. Once I get it going, it will crank over completely normal all day long. It almost seems like a fuel filter or screen is clogged and it just takes a bit to clear it out or something. Any suggestions? Thanks
