xoomer
- Cape Coral, Florida
- SX
Today I finished installing my "tow valves"--what an ordeal--and then proceeded to test them out. I started the engine, turned on the water, and everything seemed to be okay but I decided to see if there were any leaks. No problem in the engine compartment so I decided I should open the clean-out hatch since I had been working in there also. The problem was that I forgot that when I opened the hatch that it would kill the engine. So, the engine stopped but the water continued to flow through the flush hose into the engine until I was able to start the engine again--only a matter of a few seconds.
I started the engine up right away and it ran as it normally does so I doubt there was any damage but does anyone know for sure how long would the water have to run with the engine off to cause serious damage--a few seconds, a few minutes, or longer?
