Can you please explain ? Thank youPower:weight ratio
So i can just go full throttle? I thought I had to ease into it or something
You can also slam it into reverse from WOT. Just tell everyone to hold on first. Don't want to loose anyone.Yes you can just slam it to full throttle from the get go if you wish.
And make sure anything that can float is secured AND your bilge pump is working properly.You can also slam it into reverse from WOT. Just tell everyone to hold on first. Don't want to loose anyone.
