Ordering a replacement transducer- any tips?
osuart
NA
Give up and throwing the towel in. Are all AR192 transducers the same? I had water temp and depth (when it works)
Also- how hard to swap out? I can reach it and spin the ring, does it eventual unplug or more difficult than that?
assume the connector feeds into the starboard side rear are with the gaggle of connectors?
T I A - Cheers!
Has anyone here replaced theirs? I just ordered from partzilla and will get it next wk.
Really hoping its a quick swap and everything works again!
Im doing mine in the next week or so but on a different model...id be interested in how easy it is once you have access
5 minute job for me. Reached through the access panel in the back and under the cushion to plug it in. Very easy
