Port0222
- Orono, MN
Hello all --
it has been a while since I posted, so I wanted to share a simple mod that I made for my boat. We recently had a baby and needed a bimini. the stock bimini for the early AR230 is cumbersome and does not work with my speakers, Was in the way when entering / exiting the boat, and it was ugly. Not to mention that my boat did not even come with one when I purchased it.
So I purchased this: http://www.ebay.com/itm/75-85-inch-...3ade9d1&pid=100623&rk=3&rkt=6&sd=262498384539
The seller makes it clear that it will not work with double tube towers (like the AR models) -- this is because it is one long zipper in the center (Same with the boot cover) After much debate, I decided to pull the trigger and see if I can make it work.
Attached you will see some photos of it installed. I took it to my local Tailor who removed the zippers from the canopy and added Velcro (And cut a hole for the center pole) as well as added the zippers she removed to the boot cover (With the same hole) The total bill was $40
Add that to the $310 I paid for the bimini shipped (MAKE AN OFFER)= $350
Some things to note --
It does not come with adapters for a 1 7/8" tube, so I had to be a little create and use 2 adapters stacked
It is really tall -- I am 6' 5" and can walk under it
It is actually really solid at speed. no rattling or vibrating.
It folds flat and tight to the tower -- I can provide pics if others are interested.
Let me know if you have questions and happy to help -- I can also send pictures to help your tailor make the right cuts upon request.
