Hike
- Montross, VA
- SX
I received an overheating warning on my port engine as it went into 3000rpm safety mode yesterday at the end of a full day on the water. I shut down for a while to cool then it was fine on way home.
I noticed I have water coming out of 3 pee holes except the Port Exhaust port (most forward hole).
I snaked a wire through the port exhaust pee hole about 4 feet in. Didn't feel any obstructions but when I pulled out the wire, there was some oil on it. Is this normal? Starboard pee hole was clean.
Do you guys keep a hose line pinch clamp onboard incase you need to come home on one engine and not hydro-lock? I'm starting to think that would be a good idea. Wondering what tool you guys use to clamp the Y hose at the back of the engine compartment.
Thanks for the help!
