Bacchus_fl
- Orlando, fl
- SX
Hello All!
I continue to get an overheat warning sporadically on my port engine. It only happens after 30-45 min of riding if it happens at all. It does not go into limp mode but won’t clear without turning it off for about 5 min. I have checked with an IR heat gun and the effected engine is reading about 5 degrees cooler than the unedfected engine at all measuring points. Screens are clean, pee holes working great, and I’ve checked for blockage with no issues. So I believe it is a bad temp sensor? Would you agree? Is there a way to test the sensor? Clean/check them? I saw two in the manual do they both need to be replaced?
Any help with this would be greatly appreciated!
Thank you! Jason
Thank you! Jason
