Owner of factory mooring cover for 210 FSH, could you measure…
cam@LKN
North Carolina
The length of the pole at the front that keeps water from collecting on the cover. Mine got misplaced and dealer says there are multiple sizes. Thank you in advance.
Mine never came with one so I just leave the floor hatch open when covered and it keeps the water from pooling.
Mine never came with one. I have never had a water pooling issue in 2.5 years.
Thanks. Watching this installation video is what clued me into the fact it was missing. The pole and strap are mentioned and shown at the :30 mark.
I saw the same video and realized mine didn't come with any so I ordered these.
Pole
Straps
They work great but the majority of the time I try to just install snug and usually don't have any pooling.
I'm telling you guys just open the floor hatch!!! No extra things to set up or store.
You're welcome!
The video is incorrect where the zipper connects on the aft end of the ttop. The velcro goes around the upright above the hand hold. That way it holds it higher and relieves some stress from the zipper.
Just purchased a new cover for my 210 and it did not come with any support pole.
You're welcome!
Yeah I cut some pool noodle for the edge of the hatch and do the same thing most of the time. Helps to air it out as well!
On a similar topic do any of you get water pooling on top of your canvas T-Top?
I had a large pocket of water stretch out the area right above the steering wheel so I cut a 3/4” PVC pipe (with pipe insulation at the ends) and zip tied it horizontally. This kept water from pooling in that area, but then the next time I checked on the boat it pooled one section back above the seat so I had to add another pipe.
Anyone have this issue or figure out a better solution?
Bump! Same issue here interested in suggestions
I remove mine after every use it will last much longer!
It’s just got done raining here and the make shift anti pooling system worked.
Sorry for the delay on answering OP. It’s 36” In length
