OxC1 any mechanics?
Ibeflyinhigh
Check engine/stop engine
OxC1
I have unhooked the battery 10 times or more. The battery is fully charged. I took the battery in to a dealer and had it tested. It passed just fine. After hooking the battery up with key on engine off the code was erased. As soon as I start it, engine light comes on and code appears. My yami dealer is 120 miles away and they are so busy their service dept wont even return my calls to schedule me an appt.
Does anybody know what exactly this code is for? Some say low voltage. Am I safe to use the boat?
It's a 2021 ar190 with 6 or 7 hours on it.
I cant find any code sheets online.
Thanks
Double check on the system diagnostic screen. There should be another code at the lower left of the screen
Usually looks like _1_2
Which would be a code 12
This is all i have at the moment. I have a diagnostic tool being shipped so I can get the actual ydis code. thanks.
Not sure on your model but on most you hold the Sys_control button for 10 or so seconds and it will enter the diagnostic screen
