Oxygen sensor
Nova10502
Scarab
HO Impulse
Check engine light came on. Boat seems to be running fine no error codes. Pretty sure it's the oxygen sensor. Just got jet boat, can someone point out where to look for it
Sorry to double check, but many don't know the difference. Definitely the check engine light and not the maintenance light (wrench) right?
Yeah, if you have an active error code, it will be displayed in the system settings. But they can only be seen if they are active.
Note, it IS possible to have a check engine light with no active error codes. I had that situation. Required a reset via software to clear it. But if this is your problem, there's no way to know what the code is without software. You have to connect via dealer BUDS or Candoo to know what it is. So you may not know until then...
Thanks again for your quick response. Yes ,it the check engine light. I'll bring it to be checked.
Let us know what it was once you know.
