AZMark
- Phoenix, AZ
- Limited S
I’m adding mid cabin speakers and will be wiring in parallel with my existing cabin speakers to get a 2ohm load. I got that part all figured out.
My question is how to physically wire this - do I need to run two new wires all the way back to the amp and connect to the same amp ports as the existing speakers, or can I just wire them right to the connection on the existing speakers (i.e. new wire from + and - on existing speaker to same terminal on new speaker)? Wiring to the speakers would save me some trouble and quite a bit of extra wire that I don’t currently have around.
I’m not sure how the electricity flow works here or if I’d be sending too much power through the one set of existing wires to now run extra speakers.
Thanks
Thanks
