lol sooo what is the sx190's peehole name? Yesterday while washing my boat I snapped off the screw in gray elbow that comes out of it. Looking to buy another one but dont know the real name or where to look. Thanks
FYI I see now that Yamaha calls the assembly a “Pilot Water Outlet” but I recall Jet Boat Pilot referring to it as a cooling outlet which is more descriptive in my opinion but being on this sight and YJB I’m still more familiar with the terms pisser or pee hole, but if this is correct shouldnt the part or assembly be called a d ch or penis?
I think the bilge is 3/4" and the pissers 1/2". @Rick Owens replaced all of his including the bilge so perhaps he will chime in. Several members have swapped theirs out and posting info in pics buried in @SamCF 's SX192 mod thread
I REALLY like this upgrade however I just went out and unscrewed the Pee Hole and tried to pull the hose and connectors out and no give in the line. Screwed the outlet back on and said ok how does one do this? I looked in the stern starboard holding space and could not trace either line the bilge or pee hole....Request an assist from you guys on the "how-to" on this one. Thanks
Here you go. Went out and snagged some pics for you. I'm pointing in the direction of the hoses. Once you stick your head in there you will see them. The fittings have nuts on the inside/backside, not just on the outside of the hull, so that's why yours weren't budging when you removed the outer nuts. If you look close you can see the nuts . The red line is what goes to the flush port adapter in case you're wondering.
Those are very cool. Now I have two more mods on the neverending list: peckers and a fancy sphincter (gas cap)! Both sound inappropriately appropriate given the bodily references. I like heap mods like this. You can fit them between the expensive mods to keep your mod “buzz” going.
Got them in this morning looks pretty cool. Install was relatively painless, except for using the dremel barrel sander to enlarge the pisser hole about a 1/16 of an inch....
