ma11er
Hey guys i just had my two impeller refurbished by impros and bought a set of SBT pump housing with plastic wear ring and i'm having problem with the plastic liner being too tight with the impeller, so i did call SBT and they said to sand the inside of the ring to have more clearance and even it's tight that the impeller will wear the inside of the wear ring since it's plastic vs stainless .. that's what i did with tons of WD40 and guess what after a few engine turns i realized that the wear ring was seized on the impeller and turning into the housing... not good
So now i'd like to know what would be the perfect clearance with impeller and wear ring? I'll bring the housings/wear rings to my friend's machinist shop and remove what it needs
I was thinking of 0.008in between liner/impeller
