maboat
- Lake Ray Hubbard, TX
I have 3 barely used (1 season) Pioneer 800-watt Class-D amps for sale. Two are 4-channel and one is mono-block (sub amp). These are very efficient and compact medium power amplifiers. Absolutely nothing wrong with them. . They cost about $175 each new. I'm asking $75 each plus shipping but may include free shipping if one person takes the whole set.
These are stock photos but they are all in like-new condition. I will attach actual photos when I get back home later this week.
The two 4-channel amps are model GM-D9500, specs are (CEA-2006 compliant):
The 1-channel (subwoofer) amp is model GM-D7500, specs are (CEA-2006 compliant):
- FD Series Class D 4-Channel Car Amplifier
- RMS Power Rating:
- 4 ohms: 75 watts x 4 chan.
- 2 ohms: 100 watts x 4 chan.
- Bridged, 4 ohms: 200 watts x 2 chan.
- Max power output: 400 watts x 2 chan.
- Pulse width modulated (PWM) MOSFET power supply
- 4/3/2 Channel operation
- Pioneer digital signal amplification technology allows for great amplification within an extremely compact design
- Balanced isolator speaker-level inputs
- One-pair of pass through RCA outputs
- Compression-type speaker terminals
- Hi-Volt input level control (200mV-6.5V)
- Variable low-pass filter (40-500 Hz, 12 dB/octave)
- Variable high-pass filter (40-500 Hz, 12 dB/octave)
- CEA-2006 compliant amplifier
- Frequency response: 10-35,000 Hz
- Dimensions: 8-7/8"L x 7-7/8"W x 2-1/4".
- Class-D monoblock 1-Channel Car Amplifier
- 200 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
- Max power output: 800 watts x 1 chan.
- variable low-pass filter (40-240 Hz, 12 dB/oct)
- selectable bass boost (0, 6, 12 dB at 50 Hz)
- Class D amp technology and MOSFET power supply
- preamp- and speaker-level inputs
- fuse rating: 40A x 1
- 9-3/4"W x 2-1/4"H x 7-15/16"D
