biffdotorg
- Pelican Rapids, MN
- Limited S
So the 6 guide posts on our Floe lift are covered in PVC. But still they seemed to have mashed the peeholes on our 242 LS
They could have been that way when purchased, or they may have met up with a dock. Either way it was time to replace them.
I wanted something stronger, and was reading tons of threads guessing their size. I think we agreed that the inside diameter was 3/8”. And that was correct. But the diameter of the hole they are mounted in is much larger than expected. So I got a little creative.
Let’s be real, they will never have any real stress on them and they are attached to the coolant hoses with hose clamps so either 3/8 or 1/2” would have worked fine. That’s telling me they are 1/2” hoses or just stretched out.
This is an easy install and hardest part was trying to hold them on the outside while tightening on the inside. Then lining them up so they look nice. The factoey ones are keyed so that they line up and will not spin
I think these will work. Time to go test and see if I fill my cabinet with cooling water!
I think the blue anodized looks good. I lined them up a bit after the last photo. I also need to hit them with Goo Gone from the tape I used to hold them during install
