C2CMARINE
- SeaRay
- Other
my 95 searayder has a 120 hp mercury jet engine, i just bought it and the seller said it ran great, started up fine, I bought it and took it out on the water, it starts fine but at about 7-10 mph it stops going any faster, the engine sounds good, it revs up and keep sending power to the jet pump but the boat won't go any faster, I checked the ride plate and it seems to be ok, and I checked the impeller and wear ring. The wear ring has gouges around it, but there doesn't seem to be a lot of clearance but I guess I wouldn't know, I did order a manual, I'm an I/O guy and this is my first jet boat. I will attach pics of everything and I'm hoping one of you can help me. Is the ride plate not flush enough? To much clearance on the wear ring? What can I do? Thank you so much in advance for any help you can offer me!
