Mainah
- Chapin, SC
- Limited S
Limited time and quantity pre buy with only 5 units being custom made at this time! I have developed and tested a new single unit Push Button Start/Stop kit for 2015 plus twin engine boats. The kit includes custom made plug and play T harnesses that plug directly into the factory harnesses in the helm behind the ignition switches and plugs for the buttons. The harness are male/female type with top and bottom indexing slots so you can't go wrong. Mount the unit behind the helm and buttons on the dash then just plug in the connections which include the 12 pin ignition plug, 2 pin key on plug and 2-5 pin button plugs. No soldering. No wire taps. No splicing. The keys will work as they have always worked and the push button start stop will not function unless the keys are on.
My 15 year old son who is an aspiring engineer will be doing most of the work under my supervision and each harness and unit will be bench tested by me. My motivation for this is that will be both making money and developing skills with something that would not be a cost effective expenditure of my time. If he should become unable or unwilling to complete work then I will step in. We are not starting a business but rather offering one off custom wiring work and will see where it goes from there. the fuses in your boat already protect everything related to the ignition and there is an inline fuse included on the unit to protect it. Should anything ever go wrong which I don't anticipate but we should all be prepared for the keys will function as normal and if that does not work the T harness can be unplugged without tools. Unfortunately we can not make any warranties.
$199 plus free shipping in the US. PM me to secure your unit and once ready for shipment I will contact you via PM with payment details. The kits will be ready for shipment before the end of April and just in time for the season.
I may offer again in the future including for older models with the dual 6 pin harnesses depending on how this goes.
Benefits/Features of Push Button Start Stop Kit
- Single short press of start button starts both engines in sequence
- Single short press of stop button stops both engines instantly
- Keys must be in on position
- Radio stays on when engines are stopped instead of turning off like the keys
- No more long beep many times a day from turning the keys on and off
- Easy operation for non-primary operators
- 100% original function of keys, neutral safety switch, lanyard safety switch, and bilge hatch safety switch
- Taking throttles out of neutral or removing the lanyard safety will disable curious fingers from accidentally starting
- The circuit boards receive a coating of urethane seal coat to protect from moisture.
- Wire is silicone sheath individually tinned strands (marine wire)
- Final kits will have hot glue applied to the screw terminals and wires on the controller ensure they do not come free over time.
