firecap797
- St. Louis, MO
- Limited S
So when coming back into dock tonight the port engine went into overheat and then check engine. I pulled a baseball cap out of my port cleanout. It was pretty jammed in there. Now the check engine light won't go off. Water coming out of both pee holes and the overheat alarm cleared. Anyone know if this code it's showing is something that will clear on its own?
