Plugs question
ellj
What is normal plug color and is this it?
What did the end your holding specifically the electrode color look like?
The bottom of the plug might be helpful to see also.
Are you seeing normal max RPM?
Perhaps your pressure gauge was just not cooperating on that cylinder?
If compression is still zero, I would suggest trying SeaFoam spray on that cylinder in case you have a stuck valve that might loosen up, but zero compression and running engine on something so new is a rare ocurrence.
Yes, RPMs and MPH appeared normal during water test but I can re-test.
If RPM and Speed are normal, no need to mess with it, the engine is fine.
If you were trying SeaFoam intake spray it actually goes in the intake while the engine is running. Instructions on the can.
You don't need it. If you are reaching max RPM and speed, you are not on a 0 psi cylinder .
The plug looks wet, like it is not firing. Can you pull one of the other plugs to compare? How old are the plugs?
I thought normal psi was like 140ish.
Plugs are about a year old
That's off CYL1
Low compression engine generally does not make max RPM and max speed.
Can you confirm your methodology for testing? Did you open to Full Throttle? For how long did you crank? Did you take more than one reading? Did you remove other spark plugs?
Cold engine
Removed spark plug only from one cylinder
Screwed in tester
Removed safety lanyard
Cranked key until pressure gauge wouldn't go up higher
FUCK was I supposed to put throttle to max and didn't? And all spark plugs out before testing? ?
Looks the same. I assume the compression test was a cold one. If you are pulling the RPM's you are supposed to, your good. You will hear and see a misfire on the tach.
No need to remove all the other plugs but It can affect your reading slightly.
Throttle position definitely affects your reading, and would show much lower without full wide open throttle .
Thanks, I'll retest.
