Addicted
- Lake Stevns, WA
- Limited S
So, I did not like the way I installed the soundproofing on my engine hatch, so last night I removed what I had, and re-installed a different product. When complete I decided to take a look at the latch for the engine hatch. When I would step on the hatch it would drop about a half inch and make a "pop". This started towards the end of last season and I never got around to looking at it. I have also had this problem with the convertible seat since the boat was new. We typically keep that seat in the down position, so it was not that big of a deal, but when someone did sit there in the upright position (forward facing seat) the seat would pop and drop about a half inch when you first sit down or when you hit a wave. It made anyone sitting there uncomfortable, as it feels like your breaking the seat. Anyways, I take a look at the engine hatch latch and the lower pin it loose. After playing with it a bit to see if there was an adjustment, I determine that the lower pin is flat on two sides and round on the other two. If you turn the pin so that the flat edges are on the side, as opposed the top and bottom, the hatch works perfectly. I then went over to the convertible seat and the lower pin is tight, so I grab a couple wrenches and spin that lower pin 90 degrees, and bam, popping is gone!
Like I said, the pin for the engine hatch was loose, so it worked itself into the wrong position, but the pin for the seat was installed incorrectly.
