CaptRedbeard
- Omaha, NE
Had the family out with the new to us boat for the first time today. Dropped it in and both engines started perfectly at the ramp. Ran around the lake at cruising speed for 15-20 minutes then stopped (intentionally) at a sand bar for about an hour.
Went to pull away from the sand bar and starboard engine fired up but port didn’t start. Starter cranked good and strong for 5 seconds about a half dozen separate times. Tried with starboard motor running and also off.
No warning lights. A single beep (which I believe is normal) when turning the port key. Engine hatch was closed the whole time, no waves over the stern, mild amount of water from getting in/out of the boat at the sand bar. Cleanout port is clear.
First things to check? Spark? Fuel? Intake? Fuses? I’m somewhat familiar with engines but new to the Yamaha family. Thanks!
